I reckon it’s an elliptical device. I haven’t got one (not that one, nor any other type), but why would it matter? Are you looking for tips on how to best use yours?
Dominique | Finland
Just bumping this up to see if anyone has used one of these?
https://www.nordictrack.ca/freestrider
As I increase my steps (and work on intensity) my knees are starting to bug me a little. As I still have probably another 150 pounds to go I'm considering other options. I'm about to change my living situation, which would give me more flexibility on workouts. Okay, I admit it, I could set in up in the family room within view of the television and crank up the volume. I generally find straight cardio boring, and in the past, as long as I watch TV I can push myself through it. However, I do know I have to improve my cardio vascular performance long before my knees can likely take it.
My plan would be to use it to ramp up my activity level while I continue to lose weight, and in maintenance use it late fall through early spring.
@Bunnybear_05 - I see a 5i a 7i and a 9i listed. Which one is yours most like, and how do you find it?
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
@Bunnybear_05 - I know on the treadmill that I hold the handles too much so I tuck my Charge HR or Charge 2 into my bra cup. I have to do that at work as well if I'm on the plant floor so I'm used to it. I've been doing some research and have seen some very negative comments about quality and service, especially when ordering online. It would be worse here as I'm in a small town in Ontario. So, I'm likely going to go to someone semi-local so that I have a store to go back to if I have issues. The closest place doesn't carry them, but there is one maybe an hour away that does. I'm still going to look at one as I like the idea of the three options.
However, I generally look at my calories burned as my indicator of how I did during the day. I know an eliptical will allow me to raise my heart rate better without killing my knees.
Best AnswerI just bought a Nordic Track Freestrider FS7i and am very please with it. I had previously used an older Nordic Track Pathfinder elliptical.
My wife wanted to use a new machine as she didn't like the stride of the elliptical.
So far I'm pleased with this machine as it has a much longer stride than the standard elliptical.
