02-06-2016 04:01
02-06-2016 04:01
02-06-2016 07:23
02-06-2016 07:23
Aim for minutes over the mile not distance. Meaning if you hit your 3 mile target go over that for an additional five minutes or so. Ive had several severe leg injuries including a bad knee injury which was probably a direct result of never taking it easy. I'd jump from like 2 miles to six miles. I'd run on injured feet until running wasnt possible. Pace yourself.
Best Answer02-06-2016 18:12
02-06-2016 18:12
it depends what your goal is. why are you running? if its for the pleasure- the I would stay where you are. If you are training for a marathon than of course add distance. If you are doing it for cardio, than add speed- so let's say you are doing 3 miles now in 32 minutes- go for 29, then 26, etc. ultimately your answer should answer the why...
Elena | Pennsylvania
Best Answer02-07-2016 05:17
02-07-2016 05:17
Best Answer02-07-2016 12:13
02-07-2016 12:13
fair enough. I would just caution you to not add too much distance too soon. your ankles, knees, joints, hips need time to adjust to this new thing you are putting them through. be kind to your parts so they can keep performing for you...
Best Answer02-08-2016 20:23
02-08-2016 20:23
Good job @wgmsarkis! Remember, if you increase your running distance, also increase recovery time. As in, if you are currently running 3 miles everyday, then try running 5 miles, twice a week. That will give your muscles and bones time to recover. And you will find it fun to do so.
Nick | Washington
Surge, Blaze, Flex 2, Alta HR: - iPhone 7, Windows 8/10, Macbook Pro
Please mark posts as solved if you got the answers you needed, or visit the Fitbit help site for further assistance and information.
Best Answer02-09-2016 09:07
02-09-2016 09:07
As a beginner 3 miles a day is good! You can increase miles every week. With lightweight comfortable running shoes you should be able to run up to 10 miles in less than 2 hours running at a steady pace outdoors in less than a month. You do not have to run like you're racing. You will tire yourself out within 30 minutes if you do. Start at a slow pace and pick up once your muscles are relaxed usually after 20 to 30 minutes.
You will have to condition your body with the proper protein and carbs to run long distance. Research good carbs for running. Also drink plenty of water and strenthen your heart muscle.
If you're running on a treadmill, as a beginner, start at 6 mph and you should be able to run for 1 hour without stopping.
