04-28-2017 23:53
04-28-2017 23:53
Hi there,
So I'm a dog walker and I average 25,000 to 30,000 on weekdays and was wondering roughly how mamy calories in should be eating to maintain my weight? I'm 8 st 6lbs currently.
Best Answer04-29-2017 06:41
04-29-2017 06:41
@SunsetRunner, I moved this post to this Discussions Forum, as it is not related to either a hardware problem nor an app problem. It will getting more discussion here.
Best Answer04-29-2017 07:20
04-29-2017 07:20
I recommend eating the calories your Fitbit says you consumed. If you have a heart rate monitor eat 10-15% less. If you don't, eat about 10 or 15% more. If you start to gain weight, eat less. If you start to lose weight, eat more.
I don't count calories anymore. I weigh myself most days. If I'm gaining, I eat less. If I'm losing, I eat more.
Best Answer04-29-2017 08:14
04-29-2017 08:14
25-30k is a lot of steps. It’s hard to believe you would need to count your calories in order to maintain your weight at that level of activity. Are you concerned about overeating or undereating?
Dominique | Finland
Best Answer04-29-2017 09:30
04-29-2017 09:30
Best Answer04-30-2017 01:18
04-30-2017 01:18
I would think intuitive eating + weighing daily (and using TrendWeight) should work in your situation, given your high activity level and assuming you have a rather regular daily routine (not travelling for business, eating mostly at home). The rationale for TrendWeight (see link in my signature) is to avoid stressing about the natural daily fluctuations (especially since you’re a woman, because of the impact of the hormonal cycle).
If you really want to count calories, start eating 500-750 calories below what your Fitbit says you burn, just in case it overestimates your energy expenditure. If you see you’re maintaining your weight, just carry on. If you’re losing at that level, increase slightly until you reach maintenance.
You may also want to use an online calculator such as this one in order to double-check calories burned as reported by your Fitbit. With an average step count of 25-30k, I would say your activity level is somewhere between "high" and "extreme". If your calories burned from Fitbit are much higher than with the "extreme" activity level, chances are they’re overshooting.
Dominique | Finland
