04-18-2025 13:40
04-18-2025 13:40
Anyone else have issues with the not being able to see it get the steps on the app? I just switched to Google mostly because I got locked out and now I cannot access steps taken and don't see anywhere where I can add it in, anyone else having this issue?
Best Answer04-19-2025 11:15
04-19-2025 11:15
Hello @jeff9870
Which Fitbit device do you use? Are you iOS or Android user? Which version of the Fitbit app do you have?
To find your app version info:
If you can share a screenshot of what you're seeing in the app, that would be very helpful.
