03-16-2014 12:04
03-16-2014 12:04
What would calorie burn be considered for an hour of Body Pump? Frustrating that it won't sync...
03-16-2014 13:56
03-16-2014 13:56
I used to log this as 'aerobics' on myfitnesspal and I would burn around 300 calories. I am 131lbs and 5'5". Hope this helps!
03-16-2014 14:25
03-16-2014 14:25
03-17-2014 11:09
03-17-2014 11:09
it all depends on your current fitness level, how much you weigh, the amount of weight you are lifting, etc.
Could be anywhere from 300 to 700+ calories.
03-17-2014 13:53
03-17-2014 13:53
03-17-2014 13:57
03-17-2014 13:57
It would be a very long winded calculation to count each set of reps, etc. An easier way to to wear a heart rate monitor. You can buy them pretty cheaply. I wear a bluetooth connected version that cost $70, but you can get a simple watched based model for as little as $14 (the cheapest one I've bought). In my experience they all seem to give pretty much the same reading (I've owned quite few versions over the years - I have a tendency to lose them, or put them through the wash)
03-17-2014 14:02
03-17-2014 14:02
Intregued, I looked for the calorie count per hour of body pump. Its not as hight as I estimated.
Its ~480 calories per hour for a make, and ~340 for a female. You can get a lot more more details from the official body pump website.
03-17-2014 14:16
03-17-2014 14:16
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
03-17-2014 14:23
03-17-2014 14:23
03-17-2014 14:24
03-17-2014 14:24
03-17-2014 17:28
03-17-2014 17:28
I wore a heart rate monitor a few times to Body Pump and I think I burned around 380 calories, according to it. For me, that is about a METs value of 6, or 6 times my BMR calories per minute.
03-17-2014 17:58
03-17-2014 17:58
