12-25-2013 19:10
12-25-2013 19:10
how do i measure my stride length?
Best Answer12-25-2013 22:01
12-25-2013 22:01
Measure out 20 metres/yards in the backyard, walk and count 3 times or more and average your no of steps. For me I cover the 20 metres in 25 steps, so the rest is just math. 20 divided by 25 = 0.8 metres per step/stride.
12-25-2013 22:01
12-25-2013 22:01
12-26-2013 06:31
12-26-2013 06:31
The official help page is here, but I think it is better to measure over a longer but exact distance. My preference is using a high school track, which should be exactly either 440 yards or 400 meters long on the inside lane. Use the activity mode to count the steps for you, or just subtract the beginning step count from the ending step count. A 400m track is 15748 inches long, so divide that by your step count and you'll have an accurate average stride length.
12-28-2013 07:40 - edited 12-28-2013 08:07
I always thought two steps is a stride but here it references one step is a stride. I find different defintions depending on the web site I go to. Based on the distances people are referencing here it looks like it should be measures as two steps equal a stride. A step being defined as one placement of your foot in front of the other and not two movements of your foot so that the same foot is in the lead. Is this correct?
Best Answer01-27-2014 16:38
01-27-2014 16:38
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
01-28-2014 11:22 - edited 01-28-2014 11:23
Thanks....I used a 1/4 mile track and by walking and running it a couple of times took the Fitbit count and was able to calculate my stride lenght for both walking and running. It seems to be fairly accurate unless I run a lot of hills and then I am in too much pain to really care:)
04-03-2016 18:50
04-03-2016 18:50
Has there been any consideration to using the phone "track your exercise" gps function to assist you to calibrate the stride length ? That would be a very handy function, as we get in shape, and our stride length changes over time.
Thanks
Best Answer07-16-2016 22:05
07-16-2016 22:05
I always set mine to 0 as im not really good at worrying about it. im not good at this thing it might not be totally acurate but it is close enough
Best Answer02-23-2017 01:31 - edited 02-23-2017 02:25
this is an old question, but just adding my 2c:
- i install a gps logger / tracker app
https://play.google.com/store/search?q=gps%20logger
- start an activity / exercise on fitbit
https://help.fitbit.com/articles/en_US/Help_article/1935
(after that sync the fitbit & review the steps for the exercise/activity)
stride length = distance from gps logger / fitbit counted steps
i think this would be the same as fitbit app's mobile run feature/function
https://help.fitbit.com/articles/en_US/Help_article/2099
now my question about mobile run, if i turn off data and bluetooth during the exercise/walk, leaving gps on (to save battery) and only turn it back on when i do the sync, would mobile run still work correctly?
