11-22-2017 14:35
11-22-2017 14:35
i moved from my right wrist to my left wrist which has a magnetic hematite bracelet on it. maybe this is the issue.
i have not received reminders to move even tho i have put it back on my right wrist.
i know i have been very lax at actually getting up off my butt and moving when i felt the buzz and figure fitbit just quit that option.
Best Answer11-24-2017 16:55
11-24-2017 16:55
Hi @SunsetRunner. The magnet may have impacted your Fitbit. Have you tried restarting it? I'd try that a couple of times to see if it resolved the issues. If it doesn't you should contact customer support.
Fingers crossed a restart does the trick for you.
Best Answer11-24-2017 17:00
11-24-2017 17:00
Best Answer11-25-2017 05:49
11-25-2017 05:49
That shouldn't matter. What type of Fitbit do you have?
Best Answer11-25-2017 08:33
11-25-2017 08:33
Best Answer11-26-2017 05:08
11-26-2017 05:08
Sometimes when Fitbit updates settings change. Did you double check that you have the notification widget turned on? Mine was turned off a couple different times after an update.
Best Answer11-26-2017 08:46
11-26-2017 08:46
