08-21-2017 13:37
08-21-2017 13:37
I love running and walking and I track all my activities. However I don't own a bike and that is why I find it extremely weird that almost every day when I check my app I can see that I've done outdoor bike exercises!!! I'm keeping an eye on this for about a month and it always happens when I'm driving... Any idea what is going on???
I use to drive a big family car and this thing never happened. As soon as I swapped my car to an older small car this thing started... No idea what's going on!!!
Best Answer08-21-2017 19:02
08-21-2017 19:02
Don't know why that would look like bike riding, but if you want to eliminate it, you might try going to the "auto-exercise recognition" setting via fitbit.com dashboard, settings (from gear icon top right), Charge 2 (or whatever your device is), auto-exercise recognition. Then change the minimum time for "outdoor bike" to the max of 90 minutes, then sync. That means it will not count it as a bike riding exercise session if it is less than 90 minutes long.
08-22-2017 08:05
08-22-2017 08:05
You can remove Outdoor bike completely. I keep it active as it tracks pushing a stroller/mowing the lawn quite nicely.
Best Answer08-23-2017 17:03
08-23-2017 17:03
is it a manual transmission? that's the only thing I can think of because you are using both feet like you would on a bike. If you never plan on biking or at least not anytime soon, I would remove it. no sense having something that only causes questions....
Elena | Pennsylvania
