02-12-2025
10:14
04:14
DavidFitbit
02-12-2025
10:14
04:14
DavidFitbit
How do I delete or edit foods in the app? I want to remove duplicates and correct portion & calorie count for others.
Édition du modérateur : précision de l’objet de la demande
Best Answer02-12-2025 22:24
02-12-2025 22:24
Hey! To delete or edit foods, find the item in your log or search the app's database. For duplicates, search for the food and remove extras. To edit portion sizes or calorie counts, select the food and choose 'Edit' to adjust details. If you're stuck, check the app’s help section for more specific instructions.
02-12-2025 11:50 - edited 02-13-2025 04:13
Hi @TerrRo thanks for stopping by, I hope you're doing well.
Let me help you with your inquiry about tracking your food with the Fitbit app.
Depending on the operating system your mobile is running, you need to follow some detailed instructions to delete a food entry. you will find them in our help article How do I track my food with the Fitbit app?
02-12-2025 22:24
02-12-2025 22:24
