10-27-2017 13:57
10-27-2017 13:57
When you enter the components for a meal it doesn't give you the facility anywhere to say how many portions you are catering for. I try to cook in bulk and freeze some for another day but the meal just goes in as one meal (when I've made it for 4)
Best Answer10-28-2017 03:51
10-28-2017 03:51
I am not sure how many apps you want to use, but MyFitnessPal has this functionality and you can connect it to your FitBit app. Then you could log your food in MyFitnessPal with portion and it will show up in FitBit.
Karolien | The Netherlands
Best Answer10-29-2017 21:04
10-29-2017 21:04
You can also change the serving size when you log it
Wendy | CA | Moto G6 Android
10-31-2017 13:32
10-31-2017 13:32
Agreeing with @WendyB - you can log 0.25 of a serving
11-04-2017 02:45
11-04-2017 02:45
My Fitbit site doesn't give me the reduced serving size option other than to reduce it 1g at a time.
Best Answer12-02-2017 11:05
12-02-2017 11:05
My Fitness Pal has a recipe builder program so when you make say a pot of chili you can designate how many servings and calories and nutrients per serving will be computed. I like the old recipe program there.
Best Answer12-10-2017 04:30
12-10-2017 04:30
Best Answer12-10-2017 05:25
12-10-2017 05:25
Both MyFitnessPal and Cronometer are very easy to use. They handle recipes quite easily. If you spend just a bit of time with either, I think you would be pleased with the results. They both will import calories into Fitbit. Cronometer handles micronutrients if you are interested in that.
