01-05-2016 09:17
01-05-2016 09:17
I have created a recipe under my "Favorites," but I don't see where I can indicate the number of servings that the recipe makes. So after adding all of the ingredients for this recipe, I have a total of 2800 calories, but no where to say that it's divided into 8 servings. So when I enter it in my food log, I'm getting all 2800 calories added to that one meal. Can anyone help me?
Best Answer01-05-2016 21:04
01-05-2016 21:04
I typically use MyFitnessPal for my food logging so someone else might have a real solution, but you might try using the decimal of what one portion would be as your serving. So...
1 serving on Fitbit is the whole meal and you ate one quarter of it (.25 serving).
It's a bit of a work around, but that may at least get you correct numbers. Hopefully someone else knows how to work the food logging better than I do! Good luck!
