Hi,
I cut out from 2 sugars in my coffee to 1 sweetner.
ive now also cut down to not having a coffee after 2pm.
Should i make the next step and cut out the sweetner? will 4 or 5 sweetners a day be damaging my health?
Would like to know your thoughts on this.
Baz
In the grand scheme of things, your coffee drinking only plays a minor role. Coffee itself doesn’t contain any calories, so it’s what you put in it (milk, cream, sugar etc.) that matters: zero-calorie sweeteners will keep your coffee calorieless (if you drink it black). Unless decaffeinated, coffee does contain caffeine: caffeine is a potent stimulant, which can be good if it makes you more active, but it can also keep you awake, which can be bad if it negatively impact your sleep. By stopping drinking it after 2pm, you certainly eliminate that risk.
As to your question about sweeteners and health, I assume you refer to artificial sweeteners like aspartame and their alleged harmful effects on health. I’d point you to the relevant article on examine.com (good source of information for all things supplements).
Dominique | Finland
Cheers Tom, I prefer the term "Excretion" haha, however thats one way to give it up!
@SunsetRunner wrote:Aspartame is actually made from bacteria feces
One shouldn’t believe everything posted on the internet...
Dominique | Finland
Best AnswerHi there.
Dominique, thanks for a very useful article. I found a lot of important information on it that I was looking for. I'm going to try some of them. I'm also trying to reduce my sweetener from my food and beverages and change it to artificial sweeteners. I also drink coffee too much and now my goal is to cut it down for 3 -4 cups a day.
Thanks again for a good source.
Best AnswerIndeed, if you're speaking about aspartame, better stop using it. I would rather use sugar, than this garbage. As much as I know, it's not good for your health at all, and it has a lot of side effects. I can say that a good cup of coffee doesn't need any sweetener, and it's delicious on its own, but of course, it depends on the coffee beans and the coffee machine. I read multiple Keurig vs Nespresso reviews before I decided to get my Nespresso Creatista Plus, and I don't regret the purchase at all. So, stop using it, and better use stevia if you want your coffee sweet this thing you're using has nothing good in it.
Yes, I've done the same thing @AlexAlex1, instead of changing to something like aspartame, I did the same thing @SunsetRunner mentioned earlier, I just reduced the amount of sugar in my coffee and I've tried to limit sugar as much as possible in my diet.
