10-06-2020
15:50
13:48
SilviaFitbit
10-06-2020
15:50
13:48
SilviaFitbit
There does not exist any sort of list of icons (Inspire 2 ones, anyway)?
Don't think there is glossary specifically, though on-line manual probably mentions them all.
2 feet is steps; heart is heart rate; flame is calories burned; upside-down teardrop is distance (as in GPS symbol); lightning bolt is Active Minutes; little guy on one foot with arms raised is steps toward 250 for the hour.
Any others that you can't figure out?
I'm confused about the stats icons too ? What do the chevrons in a circle mean with 23 underneath? Whats does the guy dancing with 3 of 13 underneath mean? What does the guy running with 0 of 5 underneath mean? hoping someone can help
11-01-2020
10:55
06:50
AlvaroFitbit
11-01-2020
10:55
06:50
AlvaroFitbit
I have given up on things that are too "iconic".
Do you have the PDF user manual? Sometimes it has newby explanations.
I've wondered about the dancing guys and the aerial view of Stonehenge too.
I don't seem to be able to pin down the URL for the dashboard on the PC. I
have been to it. And I thought I had captured the URL, but this morning
it's all "Shop Now".
07:06
04:29
11-03-2020
07:06
04:29
@Lowlands @nogrok Welcome to the Community.
Let me help you with your inquiries about the icons you see on your tracker.
What do the chevrons in a circle mean with 23 underneath? These are Active Zone minutes.
Whats does the guy dancing with 3 of 13 underneath mean? These are Reminders to move.
What does the guy running with 0 of 5 underneath mean? Daily recorded activities.
You can find the manual here. Not sure what do you mean about the Stonehenge one but you can check the manual for more information. Still most are self explanatory and you can find the equivalent on the Fitbit app that you use to sync your tracker where you can see the title and details so it helps clear the meaning of these icons.
@JohnnyRow thank you for your help here.
Let me know how it goes.
Okay, but what is the circle with a number in it? I have a circle with 81 in it, and the word "good" below it. It shows up between the sleep icon and the weight icon.
@alankjackson wrote:Okay, but what is the circle with a number in it? I have a circle with 81 in it, and the word "good" below it. It shows up between the sleep icon and the weight icon.
That sounds like sleep score. If it is on tracker, you should be able to see same number on phone app sleep tile.
Ah, of course. Obvious - not. But you are correct, that must be it. I was looking for the number on the website, and it doesn't seem to show the score, just the components. They could work on their UI. And documentation.
07:42
14:52
JuanFitbit
06-27-2021
07:42
14:52
JuanFitbit
Thank you for the attention. I was hoping I had overlooked something.
Charles
Moderator edit: removed personal information
There is still one screen I just cant figure out. Its right after the sleep screen. Some days it says no data and today its a circle with an 84 in it and says good under it. Can you help me?
@fcp1 wrote:how about 3 arrowheads on top of each other!
under then is 0 of 22
thanks
(Active) Zone Minutes - default daily goal is 22.
Johnny,
Who is the little dude icon with his arms open wide on the navigation bar at the bottom of my Home screen? I have an Inspire 2 on the Android platform.
Is he FitBit, or just some random hitchhiker? 🤫
Dr. Livingstone I presume, stepping out of the jungle gloom, into the noonday sun...
Best AnswerLike this reminder to move?
Or same guy surrounded by circle of dots showing which hours you got 250 steps.
Best Answer@nogrok Click on 'Help' at top of page, or help.fitbit.com; then click on pic of your device to go to help page for that device, including link to manual.
