How do I stop the Fitbit from vibrating when I get an incoming call?
ANSWERED
How do i stop the fitbit from vibrating when i get an incoming call? All notifications are already turned off, and notification permission disabled in Settings (i'm on an Android phone). i don't want this thing vibrating for any reason ever and it has no business being in my phone call logs, but I can't disable the permission from my phone Settings. Is there any way to stop this?
Moderator Edit: Clarified subject.
1 BEST ANSWER
Accepted Solutions
Hi, @yarrowkat that seems weird that your Fitbit is vibrating for phone calls with notifications turned off…. Just to confirm, you have turned these off in the Fitbit app and not in your phone settings somewhere?  In the Fitbit app click on your Inspire 3 and under “General” see “Notifications” .  Make sure that the button next to calls is toggled to the left and greyed out.  Also click on the 3 vertical dots and choose “Disable notifications”.  And then confirm that all notifications are marked “Disabled”.
2 REPLIES 2
Thank you! I had turned them off from someplace else in the app settings, as well as in Android settings, but wasn't aware that there was a second menu of notification settings under the device link. Several were still on in that secondary menu! So now they are all turned off and I did the additional Disable Notification as you suggested. Hopefully this will do it! thanks!
