07-12-2023
01:51
14:38
JuanFitbit
07-12-2023
01:51
14:38
JuanFitbit
I can't add activities like yoga, pilates and other to my activities and can't delete the activities I want to ignore.
Best Answer07-12-2023 02:36
07-12-2023 02:36
Hi, @Tawa , you can’t do this on the Fitbit itself. You need to do it in the app - and you need to do it in the right section of the app. The auto recognized exercises cannot be deleted, only ignored, and you cannot add any exercises to that list.
But you can delete and add yoga and Pilates and just about any exercises that you can track using the exercise app on your Inspire 3. To find where, from the opening “Today” screen of the app click on the person photo/icon top left and then click on the picture of your Inspire 3. At the bottom of the next screen you will see “Exercise shortcuts” . Click on that, and you will find a list of 6 exercise “shortcuts”. To add a new one, if there are already 6 there you will need to delete one you don’t use. Once you have deleted one or more exercise shortcuts the option to add one will appear. Choose from the list - yoga and Pilates are both there. (Tip you can re-order the exercises to put ones you use most at the top by dragging and dropping.)
Once you have added your exercise be sure to sync your Inspire 3 so that the changes you make in the app are reflected on your wrist.
When you are ready for your workout, yoga practice , Pilates class etc, you will need to manually start and end your exercise/practice. On your Inspire 3 swipe left until you come to the exercise app. Swipe up to find the exercise you want, then tap to begin. Don’t forget to stop your exercise when you finish! Once you have synced your activity will appear on your exercise tile on the Today screen. You can tap to see details of heart rate, calorie burn etc.
I hope this helps. Welcome to the forums!
