06-16-2024 03:17
06-16-2024 03:17
So my Inspire 3 is only about a year old, up until now it's worked perfectly and I haven't had any issues with it. Then yesterday, out of nowhere, the battery started draining ridiculously fast for no apparent reason- no changes to any of the settings, no damage, etc. It's gone from only needing to be charged about once every 10 days to chewing through 100% charge in a few hours. The colours of the display are looking off too, (I haven't changed the display settings) they're much paler than usual, almost white instead of purple even though the screen brightness is the same as always. I've tried restarting it but no luck and still waiting for Support to get back to me. Has anyone else had an issue like this? I'd really appreciate any help.
Best Answer06-18-2024 06:00
06-18-2024 06:00
Hi Gomenam,
Same here! just over the last week , battery is erratic, but mostly draining within less than a day now.. haven't noticed difference in colours of display though, Help would be most appreciated !
Best Answer06-19-2024 14:17 - edited 06-19-2024 14:35
If you have confirmed that none of your Inspire 3 settings, like screen always on, etc., are responsible for the increased battery drain, performing a Factory Reset on the device would be the next logical step in my opinion.
Best Answer06-20-2024 09:23
06-20-2024 09:23
Best Answer06-20-2024 11:48 - edited 06-21-2024 07:32
Welcome to the forums @gomenam @TinaJB
Good to see you participating and providing help @Bill_209.
Please confirm that you have followed the steps listed in this help article: Can I extend my Fitbit device's battery life?
If the issue isn't resolved yet, the best way to get help is contacting with Support.
Best Answer06-20-2024 18:57
06-20-2024 18:57
I agree. I’ve had mine for quite a bit longer than that, but just recently in the last week or so the battery has depleted much more quickly than ever before. I’ve been accustomed to going 2 weeks or even more before needing a charge.
Best Answer06-21-2024 01:43
06-21-2024 01:43
Best Answer06-21-2024 06:48 - edited 06-21-2024 06:49
If that's the case, then it is unfortunately time to replace the Inspire 3, which is hopefully within the Factory 1-year warranty time frame for getting a replacement device.
