07-17-2024
20:16
11:50
07-17-2024
20:16
11:50
I just got this fitbit inspire 3 in the afternoon, and it totally fine, but when i got on my bed and change some set up and it just keep count and it over 50,000 steps, and direction go over 100km, and also the calories burned too. I see the senser green is running over that time too.
Best Answer07-20-2024 11:52
07-20-2024 11:52
Hi there, @Badcjss. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand your concern, I will do my best to help you with this.
By any chance, do you have MobileTrack also linked to your Fitbit account? If you do, please note that MobileTrack could be tracking those extra steps. To verify this, please in the Fitbit app, tap the Today tab > then tap Devices. In this section you'll see your Inspire 3 and below your phone (in case MobileTrack is indeed connected).
If the above describes your situation, you can remove MobileTrack by tapping on the phone's icon and then select "Remove From Account".
In addition, I'd suggest to confirm that the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How does my Fitbit device calculate my daily activity?
Also, please keep in mind that excess vibration might cause extra steps. Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps.
Best Answer07-21-2024 07:13
07-21-2024 07:13
Thank you so much!!!
Best Answer07-22-2024 04:27
07-22-2024 04:27
@Badcjss You're welcome!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
