03-23-2025
21:31
04:39
03-23-2025
21:31
04:39
Hey everybody,
I was wondering if it is normal for a Fitbit inspire 3 to count steps that it does not need to count (false steps). Is it only me?
Even when I was sleeping it still counted steps even if I was not walking.
Hi there, @Inspire3fit. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Inspire 3 is adding more steps than it should. I understand your concern, I will do my best to help you with this!
Before we can work on this together, could you confirm if you have MobileTrack connected to your account? MobileTrack is a function that allows you to track basic information using your phone's sensors when a Fitbit device isn't nearby. If this is correct and there was a fan or something buzzing nearby, you might get extra steps as this function might think you're exercising.
Assuming this applies to you, I'd recommend removing this function from the Fitbit app and monitoring your watch's behavior afterward. For instructions on how to remove a device, see this help article.
On the other hand, I was wondering if you're wearing your Inspire 3 while sleeping or you take it off? If you remove your Inspire 3 (or any other Fitbit device) and lay it face up on a reflective surface it may detect the flashing LED and produce "ghost" data, sometimes steps or HR. Try lying it face down (and on a non-reflective vibration-free surface).
Last but not least, keep in mind the algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement, such as working or cooking, you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats.
