04-17-2025 03:06
04-17-2025 03:06
Pressing the side buttons on my inspire 3 causes it to vibrate, the screen flashes on and off and then it turns off after a few seconds . Pressing side buttons again allows it to restart but the problem recurs the next time the side buttons are pressed.
If I move my wrist to autowake the screen everything works as normal, until I press one of the side buttons.
I’ve reset the watch through the menu, and also force reset it by plugging in a holding buttons for 10 seconds. I’ve also updated the watch’s software (using app on my iPhone), and removed/re- paired the watch with my phone.
Best Answer04-17-2025 03:14
04-17-2025 03:14
In addition, I’ve just tried to use it to track a workout - starting the workout manually. As soon as the workout starts the usually display appears but it bounces up and down and then the watch turns off.
Best Answer04-28-2025 01:54
04-28-2025 01:54
I recently have this issue too.. anyone can advise? Isit because of the update version cause this?
