10-28-2025 05:05 - edited 10-28-2025 09:59
My Inspire 3 no longer receives notifications. The other settings do work and it does sync for steps, sleep, heart rate, etc. The Fitbit Android update was completed a few days ago. I have tried uninstalling and reinstalling the App on my Android cellphone several times; I have restarted my Inspire 3 while charged and not charging; I have tried to single out specific App Notifications, rather than "mirroring" my phone; I have unpaired from Bluetooth, and then re-paired; I have confirmed that all the settings on my cellphone are correct for Notifications. All of these I have done multiple times. I initially thought there was a problem with my Inspire 3, but this Forum shows that it is not just me. Can Fitbit please solve this problem? Additionally, I have successfully received all notifications in the past, with the Fitbit App constantly installed; but now when I turn off Bluetooth, then immediately turn it on and press the "Inspire 3" "Paired device," the following message appears: ""An App is needed to use this device," even though the App is present and has been updated.
11-17-2025 15:50
11-17-2025 15:50
I got an email that says all is fixed. Mine is not!
Best Answer11-17-2025 22:08
11-17-2025 22:08
No use, I have tried many many times.
Not only this problem, all the problems required lots of time to deal with but failed again again.
And now I have to spend another lots of time to post these problems here and no solution.
so frustrated!
