Inspire 3 stopped receiving notifications
ANSWERED
My Inspire 3 no longer receives notifications. The other settings do work and it does sync for steps, sleep, heart rate, etc.  The Fitbit Android update was completed a few days ago. I have tried uninstalling and reinstalling the App on my Android cellphone several times; I have restarted my Inspire 3 while charged and not charging; I have tried to single out specific App Notifications, rather than "mirroring" my phone; I have unpaired from Bluetooth, and then re-paired; I have confirmed that all the settings on my cellphone are correct for Notifications.  All of these I have done multiple times.  I initially thought there was a problem with my Inspire 3, but this Forum shows that it is not just me.  Can Fitbit please solve this problem?  Additionally, I have successfully received all notifications in the past, with the Fitbit App constantly installed; but now when I turn off Bluetooth, then immediately turn it on and press the "Inspire 3" "Paired device," the following message appears:  ""An App is needed to use this device," even though the App is present and has been updated.
46 REPLIES 46
They had a new update and it fixed it for mine
Did you try unistalling and reinstalling the app  with rhe new update that seemed to work for me
Didn't work for me, unfortunately.
Thank you so much Bunnixo. This worked for me and I am keeping my fingers crossed that it keeps working.
So my notifications just started working spontaneously. I guess maybe they fixed it, finally!
Thanks Bunnixo, worked for me!
Thank you so much! That worked!
I am the author of this comment.  As of 11:02 am (EDT) today, my Inspire 3 came back to life and began sending Notifications.  I have not had to restart or reinstall the App, so unless it stops Notifications again, my problem has been solved.  I had checked for updates at numerous times during the day, and there were none.  I hope everyone else with this problem has had a similar revival experience.  Thanks, everyone.
This is exactly what happened to me about 2 hours ago.
What if you don't have an android update?
charland.bob. Try the fix suggested by Bunnixo earlier in this thread. It worked for me and for others.
This also worked for me! Thank you so much
Hi Everyone.
Thank you for the comments and the new information provided.
We are pleased to inform you that the notification bug has been resolved. If you continue to experience any issues, we recommend either force stopping the Fitbit application or restarting your phone.
Some additional information that might help certain people.   I haven't received any system or app updates and I've tried everything like others have stated. For me, the key was REPLACING my inspire 3 device in the app with a new device. This is done in the Fitbit app by selecting your Fitbit in the top left hand corner and then going to the add more devices button and selecting inspire 3. All I did was add again my EXISTING Fitbit device as a replacement device.  Prior to this I had just reset the Fitbit app by clearing its cache and data but I'm not sure if this step is needed.  I did have to set up my Fitbit device preferences again but it did immediately fix the notification problem.  One additional thing I noted was that when I was pairing my device again with the app, I had to have my Fitbit charging (pairing wouldn't work without the charging cable plugged in).
Hope that helps.
I am having the same problem.. stopped working over a week ago.  I have force closed, uninstalled, re installed, contacted help support and I am STILL not receiving notifications or vibrations for my WhatsApp messages.  And, yes, I have checked that DND is not on.  I am getting very frustrated as I quite often have to have my phone on mute and rely on the vibration to notify me.  Vibration works for steps etc!!  When will this be fixed?
When I kept replacing the device in the app I never had it plugged in and it worked just fine but you need to have an updated version to get it to work correctly
I have tried both of these.  Still not getting notifications.  My last correspondence with my case number on Nov. 6 said this issue is still unresolved.
I need the notifications.  I have not had my Inspire 3 a year and feel like I am going to have to purchase a new watch.  Disappointed in Fitbit.  This issue has been going on 3 weeks for me.
I have the same issue. The support of google is really useless and I can only give up and create another google account JUST FOR MY NEW FITBIT DEVICE. But now another problem is my apps notification setting page is blank, I have restarted device, uninstalled apps, unconnected and connected device, and failed many times. Very tired and frustrated, I feel very depressed and angry and I am considering to throw this device into my rubbish bin. This problem occurs since September and it still exists. 😞
Hello @Yvonnemi!  It's great to see you in the Community!
Thank you for sharing the details about your Inspire 3 that is not receiving notifications. I understand how you feel and will do my best to help you.
In the following help article you can find all the steps to set your notifications, even if you have an iOS phone you will find some useful tips: How do I get notifications from my phone on my Fitbit device
I got a similar issue like you. Do you get any advice how to fix ? Very frustrated indeed.
Thanks
