10-22-2024 13:20
10-26-2024 05:24
10-26-2024 05:24
10-26-2024 09:12
10-26-2024 09:12
It is all Android phones. I have tried 2 of them. Tried on an iPhone and it worked.
10-26-2024 09:23
10-26-2024 09:23
I had the same issue, someone suggested to install an older version of the fitbit app and that worked (but I lost some of my data). At least it reconnected and now syncs again...
10-26-2024 10:02
10-26-2024 10:02
Just as additional info - I have an inspire 3 that I sync with my iPhone. I'm not having any problems. So maybe it is just android users?
10-26-2024 10:27
10-26-2024 10:27
10-26-2024 10:28
10-26-2024 10:28
10-26-2024 11:02
10-26-2024 11:02
Using fitbit 4.26 (instead of 4.28) version was suggested in another topic, i googled it and found it online
10-26-2024 11:21
10-26-2024 11:21
I've got the exact same problem and did try all that's suggested too.. aside previous post from mine. Did it work? Because yes, it's Very Frustrating it all of a sudden stopped syncing like that and not being able to find a solution anywhere! Even the moderaters here have gone quiet?
10-26-2024 11:30
10-26-2024 11:30
10-26-2024 12:27
10-26-2024 14:19
10-26-2024 14:19
So far it worked, the only thing is that the app lost the data from the period that I couldn't connect. I still hope to retrieve those, as I read on several posts that the device should store the data for a week. But after installing the older fitbit app, my inspire 3 connects and synchronizes. (I did that yesterday afternoon, so fingers crossed...I turned off automatic updates for now)
10-26-2024 14:35
10-26-2024 14:35
Can u please tell me how I change it back to the 4.26 I'll give it a go
Thank you 😊
10-26-2024 20:45
10-26-2024 20:45
10-27-2024 00:36
10-27-2024 00:36
Updated Galaxy A13 software this morning (27th Oct) after notification of availability - but last sync still 24-October.
10-27-2024 00:55
10-27-2024 00:55
Got mine back to work by installing older version too, with same result as Inspire3N (am missing 2 days). Was quite a scary puzzle (downloading from another party then google play) and turning off automatic downloads and NOT update to latest version when asked!!) So I won't recommend it unless you're like "got nothing to loose and know what I'm doing".
I sure hope they'll fix that update asap because they should be ashamed for having caused all these upset owners.
10-27-2024 08:45
10-27-2024 08:45
Where is a reply from customer service regarding this issue?? I also have a Samsung A13 & have not been able to sync for days. Come on fitbit/Google get this issue resolved ASAP!!
10-27-2024 08:48
10-27-2024 08:48
10-27-2024 09:38
10-27-2024 09:38
I got a reply from developer finally. Tried all suggested but does not sync. At this point have latest Android os, latest fitbit, paired Samsung A13 and old firmware. Tries to sync but cannot. Reluctant to Uninstall app again because it takes time and last time could not get it to pair
10-27-2024 12:11 - edited 10-27-2024 12:34
You'd need to install an older version of fitbit. Latest (4.28) is screwed, won't pair let alone sync) 4.27 is working fine.
But I get the impression people are just posting problems here but not reading what's said on topic so far. Guess employees are having the weekend off. And why shouldn't they, since they can't help anyone anyway cuz what we all need is a 🤬 software update that's working.
10-27-2024 13:15
10-27-2024 13:15
Same here… 🥺
