11-20-2023
04:18
12:54
11-20-2023
04:18
12:54
device is tracking according to phone app, but screen shows only 5 dots. Attempts to reset failed. Saw suggestion to change clock face, but when I select "gallery" in app, message is "oops, looks like there's no Internet connection". That's not true because "how to use" and "accessories" work just fine, and it's syncing. About ready to toss it in the trash.
Best Answer11-20-2023 12:58
11-20-2023 12:58
Hi there, @k2mo. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that your Inspire 3 is stuck on that message. I understand how you must be feeling. I'll do my best to help you with this!
As a first approach, please note the "Oops no internet connection" issue can be caused by the use of the following on your phone:
If you found out that some of the above was causing the issue, correct it and then, try changing the clock face once again.
If you keep getting the Fitbit logo only, let me know so I can continue assisting you.
Hope that helps!
11-20-2023 12:58
Hope that helps!
Best Answer11-20-2023 16:59
11-20-2023 16:59
Thanks! That was indeed the problem. My husband the IT Security Professional had put a private DNS on my phone. He knows I have absolutely no clue :). He disabled it long enough for me to get my clockface etc back.
11-21-2023 01:49 - edited 11-21-2023 01:49
@k2mo Awesome! I'm glad to hear your issue is solved now. 😊
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
