01-08-2023
17:23
21:40
YojanaFitbit
01-08-2023
17:23
21:40
YojanaFitbit
I got the inspire 3 a couple days ago. The time on the clock is wrong. I tried syncing it, charging it, factory reset, just turning it off and on again, tried adding a new device on the app using my device. nothing has changed the time. Does anyone know how to fix this?
01-10-2023 07:36
01-10-2023 07:36
Hi there, @Stewy815. Welcome to the Community Forums. Thanks for the details provided in your post, you did an excellent job trying those steps.
Note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
01-10-2023 07:36
01-10-2023 07:36
01-10-2023 18:29
01-10-2023 18:29
Yes!! thank you!! changing it to a different time zone and then changing it back worked!! thanks again!
01-11-2023 14:03
01-11-2023 14:03
@Stewy815 I'm glad this work for you. If you have time please check our Health & Wellness boards where you will find other members sharing their experiences and tips for an active lifestyle.
Keep up the super stepping!
