02-08-2025
06:01
09:09
02-08-2025
06:01
09:09
Hi all, I need some quick help with turning off vibrations.
There are only two (2) reasons I want to feel a vibration, my alarm clock, and my 60 second timer between sets.
i turned off AZM on the watch and for every exercise IN the watch. I turned off auto start exercises and their related AZMs.
Problem: There seems to be another hear rate metric that buzzes my watch. It has the same symbol as AZM but my AZM says 5, while this one is going on 90.
You may imagine how annoying it must be to set a timer for cool down and the watch vibrates 6 times in 60 seconds. Another 4 times during the set. And then repeat during rests. Absolutely horrendous.
I looked and looked in the watch, on the IOS app, everywhere. I cannot find where to turn this vibrator off. Please help.
02-15-2025 08:22
02-15-2025 08:22
Found a temporary work around. It does cause less annoying issues but DND did not work but SLEEP mode did. I could use my timer without additional buzzing during my workout.
Now then, despite the bandaid fix. I’d like to know what I can do about the weekly zone minute counter.
I see no settings for TOTAL zone minutes, that is what keeps buzzing. DAILY azm doesn’t buzz anymore, but total does.
Having goals at 1 and at 2880 had no effect.
Tried deleting data. Nothing.
DND. NO
All the resets and restarts and redownloads helped none.
Where is the setting for total zone minutes?
02-17-2025 09:11 - edited 02-17-2025 09:20
Hi there, @EdgarasA. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is still vibrating even when you've found a workaround. I understand your concern, I will do my best to help you with this!
To better assist you, please make sure you've turned off the notifications by following the steps below:
Heart-zone notifications you receive during everyday activity:
For more information, see What are Active Zone Minutes or active minutes on my Fitbit device?
Best Answer02-17-2025 10:55
02-17-2025 10:55
I have done this for every exercise. And AZM is off as well in the regular settings.
AZM for daily doesn’t buzz. Only the cumulative zone minutes.
