01-20-2024 13:25
01-20-2024 13:25
My Fitbit inspire 3 won’t sync to my iPhone. I’ve tried all the options such as forgetting the device, turning Bluetooth off, restarting the the device etc and nothing seems to be working. Can anyone suggest what else I can do?
01-20-2024 15:02
01-20-2024 15:02
Got the same probleem. Watch shows wrong time and date. Also stepcounting and that kind of informatie Does nog work. No where be found how to solve problem.
01-21-2024 09:29
01-21-2024 09:29
I'm having the same problem. It won't sync to my phone. Tried deleting the app, and reinstall but it won't pair.
01-21-2024 10:53
01-21-2024 10:53
Having the same problem!
I've reset bluetooth; restarted watch on charger... still no go.
01-22-2024 04:38
01-22-2024 04:38
I have the same problem. It used to sync without problem and now it seems to get halfway and get stuck. Have tried the same things.
01-22-2024 18:56
01-22-2024 18:56
Me too. Started a few days ago and I would have to click several time before it would fully sync. Seems at the moment it won’t sync at all. It used to sync without any intervention on my part.
01-23-2024 02:12
01-23-2024 02:12
Me too. I've tried reinstalling the Fitbit app and my Inspire 3, switching bluetooth off and on. It just won't find the device for the bluetooth pairing.
01-23-2024 05:49
01-23-2024 05:49
Update- finaly it worked. Hopefully next time it Will sync withoute me having to do anything
01-23-2024 09:03
01-23-2024 09:03
I have the same problem about wrong time, and it won't sync. I deleted the app and reinstalled it, but so far it won't sync and this is 4th day. I don't know what to do to resolve.
Best Answer01-24-2024 08:30
01-24-2024 08:30
I’ve got the same problem - it stopped syncing in the middle of the day yesterday
Best Answer01-25-2024 01:52
01-25-2024 01:52
What did you do to make it work? Im having the same problem 🙏
Best Answer01-25-2024 06:16
01-25-2024 06:16
I just again started syncing, and about the 3rd time it finally connected.
For me a wonder that finally, after about a month and just after replying on this post I finally got it to work. I was so disappointed in the inspire3, with my old Fitbit I never had any problems, I did not have to do a thing to get it syncing, but the band got broken at the connection point to the Fitbit, so I had to get a new Fitbit. And with this one I have to sync or update the Fitbit myself, gets me irritated when it does not work….
01-26-2024 09:43
01-26-2024 09:43
I have to turn off bluetooth and turn it back on every time I want to sync,
then I have to click sync in the app, sometimes more than once until the
bar goes all the way across.
Best Answer01-26-2024 12:02
01-26-2024 12:02
Welcome to the forums everybody.
Thank you for taking the time to share all about what you are experiencing with Inspire 3. Sorry to know about this difficulty.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If your device is unresponsive:
If you're still having any issues, please try all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Best Answer01-27-2024 12:00
01-27-2024 12:00
What does “force quit the app” mean? How do I do that on an iPhone?
08:32
06:03
ManuFitbit
01-29-2024
08:32
06:03
ManuFitbit
What did you do to get it to sync? I haven't synced since Nov 3. I can't synced to Windows laptop, iPad or iPhone.
How do you press and hold the buttons on Inspire 3?
Best Answer01-29-2024 09:48
01-29-2024 09:48
I did it with my iPhone. iPhone and Fitbit in chargeren and close together. And all of A sudden it did not stop and I got it updated. Totday A new update-massage. I Will never learn, because since this morning it keeps in The sync-modus.
I realtime think The Fitbit 3 Does not work with The iPhone. It keeps hiv-infectie problems…
Best Answer01-29-2024 09:49
01-29-2024 09:49
It keeps giving problems….
Best Answer01-29-2024 10:15
01-29-2024 10:15
Was going nuts trying to figure out on my own and got no where. Finally came into here and tried this.
Got mine to re-sync by doing this:
