08-15-2024 05:06
08-15-2024 05:06
Since the last update my iphone has correct time and the INSPIRE is showing time of 3 hrs BEHIND my current timel. I am in Eastern time and watch is 3 hrs behind.
unpaired watch to iphone, turned off bluetooth. Restarted phone. Checked for updates (none) Turned bluettoth back on, paired Inspire to phone ( NO CHANGE)
PLEASE FIX. Not sure how much longer I can bare being in a different time zone. (I am in ontario, but the time zone on watch is British Columbia)
Best Answer08-15-2024 10:58
08-15-2024 10:58
@MakMak Thank you for your help.
@Stormigrl , A warm welcome to the Community! Thank you for your message and efforts.
Adding to what our friend MakMak mentioned, I recommend you to have a look at this: How do I change the time on my Fitbit device?
Best Answer08-15-2024 10:45
08-15-2024 10:45
Hi, @Stormigrl! Have you tried manually setting the time zone? Go into settings, date/time/units, and turn off automatic time zones.
MakMak | Community Council
08-15-2024 10:58
12:52
17:41
AndreaFitbit
08-15-2024
12:52
17:41
AndreaFitbit
Turned out a friend of mine found the solution on another site. We had to completely remove the watch from the iphone and then readd it back on phone. Through the watch app (disconnect watch ) Then the watch corrected itself.and then re-add it back as if a new watch . Watch n iphone now working yay. But thanks for the other advice
Thank uou happy to be here
