05-11-2025
21:21
10:33
05-11-2025
21:21
10:33
My wife has been a happy inspire 2 user for years. We bought the inspire 3. We can't pair it no matter what we try. I am returning it tomorrow and wondering if we should even bother since we've wasted 3 hours on this now. Does this product actually work?
We always get as far as "Something went wrong" after putting the code.
We've tried the following:
The only thing we haven't tried is a "factory reset" of the inspire 3. All of the youtube videos show how to perform the reset assuming the tracker has menus to peruse. Ours doesn't because it's either shows the date, time and battery % or a message to download the app. "swiping" up or down doesn't do anything.
This is a last ditch effort to see if there is something else we missed as I am returning this tomorrow. But even if we did, it shouldn't take this long and be this complicated to set this up so we are having second thoughts about even buying a replacement.
Does anyone have advice? Thank you.
05-12-2025 10:51
05-12-2025 10:51
Hi, @socrates399 welcome. If you are using an old cellphone, you should review this article How do I use the Fitbit app on my Android phone? - Fitbit Help Center. From time to time, Fitbit moves the minimum OS forward; follow the link to check your position.
I hope this helps.
Cheers
Gr4ndp4 | UK
05-12-2025 10:51
05-12-2025 10:51
I hope this helps.
Cheers
Gr4ndp4 | UK
05-12-2025 12:27
05-12-2025 12:27
Thank you for responding. I checked my wife's android phone and it's running Android 10. Kernel 4.4.177. It looks like Fitbit requires Android 11. It's a shame because the phone works fine but I guess this is a contributing factor. I will see if we can upgrade the O/S.
