08-31-2023 08:04
08-31-2023 08:04
I really like my Inspire HR, except that I can't put the screen in the order I want, which means I have to scroll and scroll to get to what I use most, and I absolutely HATE that. Has this been fixed in the Inspire 3? Can you decide what order to put the stuff it tracks?
Thanks!
08-31-2023 11:52
08-31-2023 11:52
Hi, @hollie68 , you can change the order of the Exercise Shortcuts. You do this on the app. From the today screen tap the icon top left, then choose your device picture (Inspire 3) and go to Exercise Shortcuts. The maximum allowed is 6. You can change your chosen exercise shortcuts to add or delete shortcuts, and you can also reorder how the shortcuts appear on your wrist by using drag and drop to reorder. Be sure to sync your Fitbit whenever you make changes in the app.
Unfortunately, except for changing the order of the individual shortcuts in the exercise app on your Inspire 3, you cannot change the order of any of the other apps, on the Inspire 3. Swiping left you will find Notifications, Exercise, Relax, Alarms, Timers and the order cannot be changed. Swiping down are various settings: Auto wake, DND mode, Sleep mode, Find Phone, On wrist/on clip, Water lock, and Quick Settings (Display settings, Quiet Mode, HR on/off, Active Zone Minutes on/off, Button Lock, Vibration strength, Device Info, and Restart). None of these can be reordered.
I hope this helps!
08-31-2023 11:52
08-31-2023 11:52
I hope this helps!
09-04-2023 07:03
09-04-2023 07:03
Thanks, I was afraid of that!
Hollie
