05-02-2023 03:52
05-02-2023 03:52
So far, it doesn't look like there are many options for replacement wristbands for the Inspire 3. I did get a pack of nylon mesh straps from Amazon (brand - Bcuckood), but I'd love to see more options, like what is available for earlier models on strapsco.com.
Does anyone here know how long it usually takes for outside companies to start making compatible wristbands for Fitbit products?
Best Answer05-02-2023 04:10
05-02-2023 04:10
Hi, @Vtbookgirl , I think the problem with the Inspire 3 is that some of the Inspire 2 bands fit, and some don’t. I have both Inspires (2 and 3) and a number of bands, and after a fair bit of investigation I think I can confidently say that the soft bands (leather, cloth, silicone, nylon) fit well, but the hard ones (any band with a metal attachment) do not fit. So if you are after a metal one go for one designed specifically for the Inspire 3. Otherwise you have the full choice of the Inspire 2 bands.
(The short answer is that replacement bands come pretty quickly - so I think lake of choice for the 3 is because of the partial compatibility, and it may not improve a whole lot, unfortunately.)
I hope this helps.
05-02-2023 04:10
05-02-2023 04:10
I hope this helps.
05-02-2023 04:25
05-02-2023 04:25
Thanks for the tip!
