05-13-2023 16:21
05-13-2023 16:21
Not showing up
Best Answer05-14-2023 11:09
05-14-2023 11:09
@Rachelllll33 , A warm welcome to the Community ! Thank you for your message.
Do you see the sleep stages record or the simplified sleep record?
If you see the simplified ones, this could explain the situation.
The following conditions can prevent the recording of sleep stages:
- You record your sleep using the app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (below 25%). This prevents a regular recording of the heart rate.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You should be able to put your index finger between the bracelet and your arm without much resistance, so that your heart rate is recorded regularly and the sleep phases can be recognized.
