02-10-2023 03:31
02-10-2023 03:31
what is this and how to set it
Best Answer02-11-2023 05:08
02-11-2023 05:08
Hi, @Taxvol , I am not sure that I understand your question. Where are you seeing this setting?
The Inspire 3 has (in my personal experience) an amazing battery life - I always get a week or more. There really is nothing to set - but for ideal over life of your battery I recommend charging as soon as possible once it gets below 20%. Ideally you should try to avoid deep discharges, although occasional deep discharges won’t cause significant harm.
You can check the level of your battery on the Inspire 3 by swiping up from the clock screen.
I hope this helps. Please post again if anything is still unclear. Welcome to the forums!
