03-16-2025 20:56
03-16-2025 20:56
hi, i want to remove the strap from my inspire 3
the issue is that on one of the sides of the tracker, the little protrusion to help remove the strap is missing
how do i take this strap off?
03-17-2025 11:52
03-17-2025 11:52
Hi, @kraz63 welcome to the community, If you look at the other strap after you take it off you will see this -
The right-angled part with a ball on the end (Like a bolt action) seems to be inserted into the locking pin. I assume with the ball part missing there may be a small hole in the locking pin. If you insert a sharp spike into the hole you may be able to push it towards the other end & release the locking pin.
I hope this helps.
Cheers
Gr4ndp4 | UK
03-17-2025 11:52
03-17-2025 11:52
I hope this helps.
Cheers
Gr4ndp4 | UK
03-18-2025 19:19
03-18-2025 19:19
Worked perfectly. thanks!
