06-26-2019 15:41 - last edited on 06-27-2019 11:38 by AndreaFitbit
How to set Fitbit inspire sensitivity for sleep? Want more detail on sleep patterns
06-27-2019 11:50
06-27-2019 11:50
Welcome to the Fitbit Community @RickMaglich. I'll be glad to assist you with your sleep sensitivity inquiry.
Your device's setting can record your sleep in either "sensitive" mode for extremely detailed sleep reporting or "normal" mode for a more basic idea of your sleep patterns. Note that if you use a Fitbit device with heart-rate tracking to detect your sleep stages, this setting doesn't apply.
If you use the Fitbit app for Android you must change your sleep sensitivity setting on https://www.fitbit.com/
You can check help article How do I track my sleep with my Fitbit device?
Please let me know if you need further assistance.
12-11-2019 08:22
12-11-2019 08:22
I accidentally turned on my sleep sensitivity. I don't like it and want to return it to the normal setting but can't find out how to do this!
06-24-2020 15:05
06-24-2020 15:05
Hi there, I don't understand how the link you refer to if you have an Android answers the original question. I've been to the site you refer Android users to, and there is nothing regarding where the sleep sensitivity is set? What am I missing?
06-25-2020 04:01
06-25-2020 04:01
Hello @HK2029 and welcome to the Help forums. That page is your web dashboard. Tap on the Gear in the upper right, then on Settings in the drop down. You will find the sleep sensitivity near the bottom of the Advanced Settings.
Laurie | Maryland, USA
06-25-2020 05:56 - last edited on 06-28-2020 19:47 by LiliyaFitbit
Thank you!
- hk
08-17-2022 02:28 - edited 08-17-2022 02:31
@AndreaFitbit wrote:If you use the Fitbit app for Android you must change your sleep sensitivity setting on https://www.fitbit.com/
It flummoxes me why there are these odd differences between the iOS and Android apps (with no apparent goal to make them the same)?! On the iOS app you access "Sleep Sensitivity" within Sleep > Settings (last option).
11-20-2022 12:48
11-20-2022 12:48
On Fitbit.com it's very well hidden.
I finally found it, and it's normal, yet Fitbit in the last several days mostly shows me getting very little sleep, including large gaps in sleep when I really was sleeping. My only guess is that it may be hyper sensitive even in the normal setting. This has happened to me before; eventually Fitbit 'allowed me' to upgrade from Versa to Sense with a bit of money off MSRP. But from what I can tell this is more a software issue.
