Has there been an update? I have always been able to see my steps and heart rate in real time on my Fit bit ap, now instead of saying "Syncing" it says "Gathering your data" and no longer shows my current heart rate, only my resting rate. It no longer shows my steps updating either. Is this normal? I miss my heart rate as I want to know if I am in my cardio zone and if I have reached my hourly steps.
Best AnswerI called support, and she told me to reset the settings on the device itself. It worked! Scroll up & tap settings.
Best AnswerWhat device do you have? I don't have a way to reset on my device.
Best AnswerI did a reset by putting mine on the charger and holding the button. But that didn't do anything.
Best AnswerI have an Inspire HR. You have to tap the screen on the device, then keep swiping down on the screen (to scroll up), eventually you will get to "settings." Then swipe up (to scroll down) to "Reboot Device." Also make sure "Heart Rate" is ON under settings. I did this, and it took a second for my HR to start showing on the device again, and now my resting heart rate is in real time on the app. I don't think sleep can be re-evaluated, so we will see if this fixes that issue after tonight!
