08-14-2018
01:20
10:33
SantiR
08-14-2018
01:20
10:33
SantiR
I’ve been running this morning for 44 minutes. My Ionic showed 44 minutes activity. After synchronizing, I’ve been active for 15 minutes!! How is this possible? What makes this change And why? Can anyone help me? This isn’t the first time sadly.
Moderator Edit: Updated Subject for Clarity
10:32
07:06
08-15-2018
10:32
07:06
@Kaat2 Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing with the data synced to the Fitbit app while using Ionic.
Do you mean the active minutes shown after your activity? Or do you mean the total time for your activity that is changing?
If it is the active minutes, it happens because active minutes are only counted when you reach a minimum of 3 METs (metabolic equivalents) or above. These are reached with moderate to intense activity that is continuous for more than 10 minutes. It could be that you reached this for only 15 minutes on your 44 minute activity. Please check this helpful article for more details about this.
Keep me posted! ![]()
Best Answer08-16-2018 06:48
08-16-2018 06:48
Hi, it seemed that the Ionic didn’t register my heartbeat the whole practice. It had counted a heartbeat for 15 minutes instead of the whole 44 minutes. That’s why it changed the data. Thanks for replying!
08-16-2018
10:13
07:06
08-16-2018
10:13
07:06
@Kaat2 Thanks for your reply and for providing those details.
I'm glad to read you figured out what was happening for that activity. Is your heart rate tracking correctly now?
Usually, when a heart rate reading stops tracking; may be because of the placement you are using for the watch on your wrist. Check this helpful article for more details in this.
