After waiting for months, I thought the Android notifications finally worked for my phone and Ionic but how dead wrong I was. The joy lasted only for a week (yes, the past week only). I am using a Xiaomi Mi Note 2 and I know it is not on the compatible devices list for the notifications feature but it worked in the past week!!
Anyone facing the same issue and got it fixed? Please share how you got it working again.
Hello @LeonS and Welcome. I would suggest you perform a RESET on your Ionic. This is accomplished by holding down the Left and Bottom Right buttons together and keeping them held down until the Fitbit Icon appears, then release. This will usually get things back on track. Please post back and let me know. Thanks and Keep on STEPPING!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Thanks for the prompt response @GySgt_Seidell. Sadly, it's still not working after the reset on Ionic and restarting my phone. Weird thing is the Test Call Notification could be received. Very puzzling...
Hello @LeonS and thanks for the quick reply! Unfortunately, I don't use Android (iOS here) and you have probably already done this, but just for giggles, let me go for it:
1. Fitbit App Notifications: Are they ALL turned on (Calls, Text Messages, Calendar Events)?
2. Fitbit App Notifications/App Notifications: Make sure the App's on your phone are being allowed to communicate with your Ionic (Turn the individual Apps on/off as needed).
3. Fitbit App: Close the App on your phone (totally, but not deleted) and Restart the Fitbit App, than Resync your Ionic with the Fitbit App (after verifying 1 & 2 above).
4. Main Settings NOTIFICATION: Hold down the LEFT button until the Settings screen appears, then swipe LEFT till you see the Screen Wake and Notifications area. Make sure Notifications is also TURNED ON here!
Did that help at all? Please post back and advise, Thanks!
Hello @LeonS. So your Ionic is syncing to the Fitbit App on your phone properly, but no text messages and you were getting them prior. What changes have you made to your Ionic since this started to happen (Clock Faces/Apps), if you can recall? Thanks and please post back and advise!
Yep, my Ionic is syncing to the Fitbit App perfectly but no text messages are coming through now. Let's see what I could recall... I haven't touch the settings on my Ionic for ages. The only change that I could recall is the update on the Fitbit App itself. It stopped sending text messages after the Fitbit App update.
Hello @LeonS, more information for you:
Have your phone and Fitbit device nearby. Setup may take a few minutes. Since you need to make a choice about encryption, before you get started read our explanation at Are notifications sent from my Android device encrypted?
STEP 1: VERIFY YOUR PHONE SETTINGSOpen the Settings app to review your phone settings.
Confirm or adjust these settings:
Set up the notifications you want to receive on your wrist. Make sure your charged Fitbit device is nearby.
Notifications should appear on your device when it's near your phone (about 30 feet). If notifications are delayed or missing, see My Fitbit device isn't receiving notifications from my phone.
Hopefully this will get you straight. Please post back and advise. Thanks!
Sorry for the late reply @GySgt_Seidell. Tried all the steps (even the ones in the help links) but still giving me the same old trouble.
16:13
07:21
08-06-2018
16:13
07:21
@LeonS I hope you're doing well! Thank you for reporting the situation you are experiencing with notifications. Also, thank you very much for following the steps and workarounds provided on this thread in order to sort this out.
As you already tried all of the steps above, I believe the main reason why this is happening is because the phone model you are using is not a supported device.
