09-15-2018 09:59
09-15-2018 09:59
Hello,
My Fitbit Ionic has a feature where it can auto-pause workouts such as walking and running when it detects no motion (during rests, water breaks, etc...). However, I realized this earlier this week while doing a run that it never turns back on automatically, so my stats for the workout are incorrect. This is strange, and I doubt that this is how it is supposed to be.
Is this how it is? Or is there a way that I can fix this?
Thanks.
Best Answer09-16-2018 22:51 - edited 10-01-2018 00:08
I've never tried this with the run mode, but auto pause only is supposed to work with run, doesn't work with the walking mode.
BTW are you depending on the auto detect function, or have you manually started the run recording on the ionic?
09-30-2018 20:34
09-30-2018 20:34
Hello,
I was using the walk exercise feature. Also, I did not rely on auto-detect; I manually started the workout myself.
Best Answer10-01-2018 00:14
10-01-2018 00:14
Please see page 48 of your Ionic User manual for the auto pause function.
Before starting the run, tap on the settings to turn auto pause on, as I mentioned above, this feature is not available for walk.
01-05-2019 19:54
01-05-2019 19:54
I just purchased my Versa yesterday. I have it set to Auto pause. However it does not work. What am I doing wrong? As soon as I push play the clock starts. My Apple Watch didn’t start timing until I started my run. How can I fix this?
Best Answer01-05-2019 20:00
01-05-2019 20:00
When you press start, Fitbit assumed that you really plan on starting.
Now when you stop for, let's say a stop light, this is when the pressure kicks in.
Best Answer01-05-2019 20:19
01-05-2019 20:19
So don’t press start? Just run?
Best Answer01-06-2019 00:35
01-06-2019 00:35
If you want to just run, you may, and let the run be auto detected.
However I would go to run, wait for the GpS to get a lock, then press start and start running. Rather than start the run mode and hang around until your ready to start out running it sounds like this is what is being done in the original post.
Best Answer07-27-2020 21:41
07-27-2020 21:41
Thanks for the info Rich!
With this I was able to turn off the auto pause as well! Thanks again!
