05-24-2018 15:14
05-24-2018 15:14
Is there a way to turn off the backlight so it comes on manually? Older versions used to have this feature and now there isn’t an option to make it only light up when I use a button.
I work in a darktoom so that hat feature was very helpful. Now with the light coming on every time I move my arm (which not only reduces battery life) but also stuffs around with my work. I’ve had to put a band around my ionic in order not to have light leaks.
Also my ionic battery used to last 5 days. Now I’m having to charge it every 3 days. I don’t have notifications on etc...
Best Answer05-24-2018 16:52
05-24-2018 16:52
Do a long press of the left button to reach the Screen Wake setting and set it to Manual.
Best Answer05-24-2018 17:09
05-24-2018 17:09
I’ve done that as well. Unfortunately the light still comes on when I move my arm.
Ive reset the ionic a few times now and no joy.
Best Answer05-24-2018 19:28
05-24-2018 19:28
By "reset", do you mean a RESTART? In any case, try it several times before giving up. And if that doesn't work and it bothers you enough, you could try a Factory Reset back to when you first opened the box. Swipe left to settings, then about and then Factory Reset. You will then be instructed to set up
your tracker as you originally did.
Best Answer05-24-2018 20:50
05-24-2018 20:50
Ok I’ll do that. Thank you for you help.
Best Answer05-27-2018 16:33
05-27-2018 16:33
Turning the backlight to manual will not keep the display from turning on with a press of the button or touching the screen.
Best Answer06-01-2018 18:53
06-01-2018 18:53
My ionic is set to manual.
When I move my arm the light comes on. This is with nothing touching the screen and I’m definitely not pressing the button.
My solution has been to just take it off and put it in my bag. This works well.
Best Answer08-27-2018 10:15
08-27-2018 10:15
I've had no problem since setting it to manual. It only lights up when I touch the screen or press the button.
