01-26-2020
07:57
12:28
RicardoFitbit
01-26-2020
07:57
12:28
RicardoFitbit
It seems I suddenly have to charge my ionic daily or more. I used to easily get 5 days out of it. I am getting really frustrated with such an expensive product not working so quickly.
I have this exact same issue. It all started with a software update about a week ago.
Since then I have factory reset a couple of times, and removed all my apps on it. Restarted a few times, even updated it over Bluetooth instead of WiFi to see if that makes any difference.
None of that has helped!
Let’s see if and how @Fitbit helps!
12:27
16:32
01-27-2020
12:27
16:32
Hi @Fragileice37, welcome to the Community Forums! It's nice to see you again participating here @ThatKarmaThing, welcome back.
Let me share with you that the battery of our Fitbit Ionic was designed to last 5 days but this also depends on how frequently you use it’s features. That said, I recommend you guys charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much. After doing so, please this help article for more tips and recommendations.
Such article includes as restart process that will refresh the device's performance.
Keep me posted, I’ll be right here if you need anything else.
