11-28-2018 13:17
11-28-2018 13:17
Hi my ionic will not sync with my phone or tablet. I have reset the fitbit and also all apps it when I come to sync neither phone or tablet are picking up the Bluetooth on the fitbit ionic but both phone and tablet Bluetooth working
Best Answer11-28-2018 14:30
11-28-2018 14:30
May I ask what type of phone and tablet are you having problems with @Kimjulie67?
Since two devices have been mentioned, when trying to sync through the one device, make sure that the Bluetooth on the other device is turned off.
11-29-2018 23:56
11-29-2018 23:56
Best Answer11-30-2018 07:15
11-30-2018 07:15
Yes your headphones do not need wifi since they are only acting as an external speaker replacing the speaker in your phone. Now if you wanted to, let's say, listen to a YouTube video through the headphones then yes wifi out cell service will be needed.
With your Fitbit Wifi or cell service is not needed if you simply want to see what is on the tracker from your phone. This is possible because the phone is acting as a remote display, in the same way headphones are acting as a remote speaker.
Now if you would like to sync then yes an internet connection is needed because a sync requires the data from the Fitbit to be uploaded to fitbits cloud service. It is like watching a video from YouTube requires the phone to be connected to the internet to be able to get the video.
As for wifi on the ionic, this is only used when updating music, apps or firmware. Plugging in the ionic to charge will cause the ionic to connect to your router, and update music and apps. No bluetooth will be used.
Why are people so quick to do a factory reset, which only needs to be done if the tracker is switching ownership?
Have you setup the tracker as if it is a new just out of the box unit?
Best Answer11-30-2018 07:16
11-30-2018 07:16
Have you setup the tracker as if it is a new just out of the box unit? Music will also need to be setup.
11-30-2018 07:34
11-30-2018 07:34
@Rich_Laue, i think people have just got soooo used to doing factory resets all the time, because so many mods advise them to do so when as you have indicated in your post, problems can be worked out in other ways.
Best Answer11-30-2018 07:45
11-30-2018 07:45
Generally I find a mod only suggests a factory reset after everything else has failed and rarely advised by mod.
The last time I suggested a factory reset was with a Charge 4 years ago, a mod sent me a pm dating that normally we do not advice a reset but in this case they did agree with me.
They wanted to make sure I understood that factory reset should normally not be advised.
Best Answer11-30-2018 08:01
11-30-2018 08:01
Matt fitbit recommended it twice in this thread alone, yes it may be a last resort as you say, but over time others besides mods think its the thing to do and as you previously said, it becomes the thing people do. https://community.fitbit.com/t5/Ionic/Fitbit-OS-2-2-Ionic-Firmware-Release-32-12-19/td-p/2986373
Best Answer11-30-2018 09:45
11-30-2018 09:45
Best Answer11-30-2018 14:12
11-30-2018 14:12
ha mattfitbit has now posted in the above thread and advised not to do factory resets.............typical fitbit
Best Answer11-30-2018 14:25
11-30-2018 14:25
