01-10-2019 18:13
01-10-2019 18:13
Old software had a calendar face, how do i add
Best Answer01-11-2019 06:03
01-11-2019 06:03
HI, @Charlescemco. To change your clock face, open the Fitbit app on your phone. Tap the Account icon, then tap Ionic, then clock faces. Once you get to the All Clocks screen, you should see a magnifying glass icon at the the top. Tap that to search for Calendar. If the screen you want ... or one similar to it is available, it should show up there.
Best Answer01-12-2019 15:47
01-12-2019 15:47
Best Answer01-12-2019 17:00
01-12-2019 17:00
It sounds like you had a third party face installed (non-Fitbit created face). That face is not yet compatible with Fitbit OS 3.0, and hence does not display at this time.
