12-09-2021
07:51
11:56
AndreaFitbit
12-09-2021
07:51
11:56
AndreaFitbit
Can I change the level of the low battery alert from 25% to something lower - say 10% ? When I get the low battery alert, I still have a least 2 days of charge left and would like to have the alert come up closer to full discharge. It would be best if this level would be selectable by the user.
Moderator edit: Updated subject for clarity.
12-09-2021 09:51
12-09-2021 09:51
Hi, @mdvorachek! Unfortunately, you're stuck with the fixed number. However, I'd suggest you head over to the Feature Suggestions forum and propose it.
MakMak | Community Council
12-09-2021 22:46
12-09-2021 22:46
Hi @mdvorachek - you could try a clock face from the gallery that does what you want, such as the SimpleClockPro clock face which has an on the watch alert for each 1% decline in battery level from 17%.
12-11-2021
12:11
08:32
12-11-2021
12:11
08:32
Welcome to the Fitbit Community, @mdvorachek and thanks for your advise @MakMak and @Guy_. Thank you for sharing your battery level idea with us.
As @MakMak mentioned, this is a fixed number and you can add your idea to our Suggestions. You can also try @Guy_ 's advised clock face.
It's not recommended waiting until your battery drains completely to charge it again.
Keep on visiting the forums.
