10-07-2020
03:27
13:42
RicardoFitbit
10-07-2020
03:27
13:42
RicardoFitbit
What will happen if I put my Iconic away for 6mth will it charge up again after that time .
Moderator Edit: Formatting
13:42
07:07
10-09-2020
13:42
07:07
Hi @ShahzadaBabar, welcome to the Community Forums!
Thanks for your post and question. Your Ionic should charge fine if you charge it correctly. You can check: Why isn't my battery charging on my Fitbit device? if you experience difficulties charging it.
Let me know if you have any additional questions.
Best Answer10-09-2020 15:10 - edited 10-09-2020 15:16
Lithium ion batteries store quite well. It is recommended to charge (or discharge) the battery to around 70-80% before storage and then shutdown the device (Ionic). I'd probably be checking/charging the Ionic in about 3 months time back up to 70-80%. Make sure it is again shutdown from within the menu. Then give it a full charge before use.
Lithium batteries will discharge around 2%/month. Given that the battery in these devices may not be of the highest quality - from anecdotal user evidence - the discharge rate may be higher, or there could still be some residual draining from the device, even though it is shutdown. So check occasionally.
