03-20-2018 20:37
03-20-2018 20:37
With the new update, I can't find the customize exercise option. We used to be able to select 7 different exercises, like spin, weights, etc. Anyone else having this problem? I only have the auto recognize exercises. 😔
Best Answer03-20-2018 22:12
03-20-2018 22:12
same, no exercise options
Best Answer03-20-2018 23:35 - edited 03-20-2018 23:38
Are you saying the exercise app is missing from your Ionic? Or that you can't customise the exercise shortcuts in the settings on the mobile app/dashboard?
Swipe from the right hand side of the screen to the left can you locate the exercise app on any of the screens? If it's not there I would suggest trying to restart your Ionic (press and hold the left button and bottom right button together for 15 secs). If that hasn't solved the problem, go onto the fitbit mobile app, select Ionic, apps and then confirm the exercise app is installed. If it's still missing after that I would probably try a factory reset. Make sure to sync and remove the Ionic from you account before performing a factory reset, this will insure you don't lose any data and that the reset goes smoothly.
03-21-2018 15:22
03-21-2018 15:22
Best Answer03-21-2018 18:01
03-21-2018 18:01
I have mine...from the dashboard on the phone app, tap the control board (whatever you call it) in the upper right hand corner, tap Ionic, scroll down to Exercise Shortcuts, tap on that and it gives you your choices. if you have seven chosen, you need to delete one to see the other options. I just changed mine... and it carried over to my Ionic (miracle of miracles)
@Vondmomwrote:With the new update, I can't find the customize exercise option. We used to be able to select 7 different exercises, like spin, weights, etc. Anyone else having this problem? I only have the auto recognize exercises. 😔
Best Answer03-21-2018 19:55
03-21-2018 19:55
Thank you! I got it.
Best Answer03-22-2018 04:03
03-22-2018 04:03
