My ionic, went dead I did a recharge to 100 percent but then the heart rate sensor kept saying "null" and within 7 hours the device battery went to 5 percent , seconds later dies. I charge it again this time it took hours just to reach 50 percent, I decide lets tell it to factory reset and it starts resetting then shows a big X and says reset failed trying syncing. now I already deleted the app from my phone so the watch is just stuck in this cycle of the big X if I hold a button in it resets goes right back the same screen a big X saying reset failed try syncing...... help
Best AnswerI reset the watch . Then I got the “data not cleared sync and retry “. I did it about 5 times & it finally cleared . My ionic is all good now. I did the Set up again.
Best AnswerNot true, unpaired device will still result in the same defunct. There is no way around this at all as far as I'm concerned. What a disappointment.
@moodam1wrote:Not true, unpaired device will still result in the same defunct. There is no way around this at all as far as I'm concerned. What a disappointment.
You are right I think. Several people are saying it will be fine if you unpair first but my experience is that is not the case. Maybe some people got lucky. Either way it should not be an issue - a factory settings reset should be exactly that - data should be cleared and it should work like it did out of the box!
The only thing to do may be to return the Ionic and get a replacement. For what it's worth, I think this is something which can be fixed by a firmware and app update, so hopefully Fitbit will sort it at some point.
It worked for me, managed to make the red cross disappear.
I did these steps exactly:
1. Unpair the Ionic inside the App
2. Unpair the Ionic in the phones bluetooth profile. (and switched bluetooth off in the phone)
3. Switch off the Phone.
4. Hard reset the Ionic ( kept the 3 buttons pushed at the same Time.)
5. Restart the Phone. (put bluetooth back on)
6. Add the Ionic again.
Had the same issue, red cross after factory reset because it was not syncing. Yes tried everything before factory resetting this device.
Anyway, afer removing Bluetooth pairs, (yes it seemed to have two bluetooth connections?)
Then restart app and another factory reset on the watch, (by holding all three buttons for 30 second's). The app setup process complete the pairing of the Bluetooth and setting up.
Thanks for the help
Hey everyone! Thanks for the details that each of you have mentioned regarding the red x screen or the data not cleared message you were getting.
If you ever get this message or error you can try the following:
- Unpair Fitbit Ionic from your app (Ionic> settings> scroll down> remove Ionic)
- Forget the watch from Bluetooth settings
- Restart your phone
Once again, I appreciate that you've shared the solution that has worked for each of you.
I'll be around if you have any other question!
Best AnswerI had the same problem, tried all the same things. It was only when my phone battery was above 50% that it worked.
Good luck everyone
Best AnswerI have been up for 2 hours trying to fig this out. Finally came across your post, and tried replacing my versa in the Fitbit app and it worked! I had the big red circle with the X saying data not cleared resync and try again.
Thanks man that worked awesome I got my son's ionic working again. Cheers.
I am wanting to sell my Ionic, and yet every time I try to do a factory reset, it brings up that red X and says Data not cleared, sync and try again. I don't want to sync again, I want it back to the factory preset so I can sell it. Is there a workaround?
Best AnswerTry this Philvb
Best AnswerThis is a reply to 'DrBlake' post.
Hi There, tried steps 1-5, got the red X message noted in step 6 and could not progress further. Hence cannot see how it would be possible to progress to step 7 let alone step 8. Had numerous attempts and still issue unresolved :(. There must be something else or a step missing.
Best AnswerThis message is in response 'SilviaFitbit' post.
Hi, did not work following your suggestion. Red X remains despite multiple hard reset, unpairing the device both in the phone blue tooth and fitbit app, uninstall fitbit app, reinstall the app, shutdown the mobile phone, restart the mobile phone, blah blah blah the whole kitchen kaboodle. Ionic played up on Mon 12/11/18 and have invested countless hours trying to bring it back to working order. Had the device 10 months or so. Efforts and time invested was of no success, disappointed and would not be investing in another fitbit device.
The steps above did not work for me after multiple tries. The install process would fail on android and I'd be stuck with big red X.
I eventually got it to work by installing the app on an iPhone. After setting it up on the iPhone, I was able to reconnect it on my Android and it is working again. What a pain in the butt. So many hours messing with this thing! Seems like it will work for a few weeks, then notifications stop working and I have to reinstall everything.
Last fitbit for me since they haven't resolved this firmware/software issue for over a year.
Best AnswerAfter trying reset the Fitbit by going into settings, I got the error message.
After trying a few of the suggestions this is what worked for me.
Unpair from phone bluetooth
Unpair from app
Now go to add new fitbit
While it is searching for the unit, hold the 3 buttons until the app finds it, the error message then changed to the green tick and connected to the app and started downloading the update.
Best AnswerHi, gave it another attempt this evening following your suggestion using the iPhone but without success. Was hopeful although I've already bought a replacement tracker and the new device so far is without all the bugs and hiccups experienced with the ionic.
