Deleting deezer and Pandora
ANSWERED
Is there anyway to delete these from my watch?  I don't and never will use them and I don't like how they take up space. Thanks
1 BEST ANSWER
Accepted Solutions
@Leppy The trick is not to press the settings icon on the right side but rather the Deezer and Pandora icons themselves.
13 REPLIES 13
@Leppy In the Fitbit app press on the Ionic icon. This will bring up the menu where you can change watch faces, manage apps, etc. Select apps. This will bring up a list of "My App". You can select any of the apps you don't want (i.e. Pandora and Deezer) and there should be an uninstall option.
There isn't. Only thing I can do is log into those apps which I don't have an account. Seems like fitbit and those 2 companies have a deal (fitbit getting $$$$$) so you can't get rid of them. I've deleted other apps.
I deleted both of them from the app and they have disappeared from the Ionic!
I just did the new os2 if that matters.
And turned off my phone and watch
Go to app box, open and go to Pandora and Deweezer. Tab and it will open. Uninstall.
I had to install Deezer to make the below screenshots .It works the same for Pandora and Music. Simply tap where I circled. Screenshot_20180325-103559.jpg
@birdman5589 It worked! Thank you so much.
Just tap the deezer icon, don't press and hold...then you get the option to uninstall it
When I do that it wants me to go to fitbit/deezer.com and enter the activation code.
@Criscb which way are you doing this.
You can easily remove the app.
You might also want to unsubscribe from the paid membership with Deezer or Pandora.
