06-24-2019
16:59
12:14
RicardoFitbit
06-24-2019
16:59
12:14
RicardoFitbit
My Ionic has stopped syncing again. This is a recurring issue. Everything is up to date. Everything has been restarted. Last time Fitbit says the update fixed it... 3 days after I performed factory reset.
Really getting Fit-bitter with this thing.
Hi @RustyBrindle thanks for bringing this to my attention and for the information that was shared with me, it's nice to see you again participating here in the Community Forums.
Seems odd that your Ionic isn't syncing as the way we designed, I appreciate your effort and time troubleshooting this syncing situation prior posting and for letting me know that everything is up to date. Since I can really know which troubleshooting steps you tried, if you haven't already done so, please try the steps from our help article: Why won't my Fitbit device sync?. Also, can you please let me know which mobile device are you using?
Looking forward to your reply, let me know how it goes.
Thanks for your prompt reply and the details that were shared with me @RustyBrindle.
Let me share with you that your neighbors WiFi should not affect the syncing procedure of your device. In the past, it was required to connect your Ionic to your own WiFi connection because of the setup and firmware update procedure, however, for syncing there should not be any issue. That said, please make sure that there's no other Bluetooth device connected to your phone or nearby. Then, please follow the below steps. Take in consideration that some of them were already tried but the specific order is important:
Keep me posted
Welcome back @RustyBrindle your reply is appreciated. My apologies for the delay in responding.
Certainly the syncing process of our Ionic device was not designed in such way, I totally understand how frustrating this matter can be for you. Can you please let me know if you already tried syncing your Fitbit with a different mobile device or a computer? This way we will be able to know if this is occurring with your iPhone 6s or any device.
Let me know how it goes, I'll be here.
