10-11-2017 06:37
10-11-2017 06:37
Earbud volume is too high. Volume on the earbuds is turned to the lowest setting and wont turn down on the ionic, just mutes volume.
Volume is so high i can't hear traffic noise.
10-11-2017 13:08
10-11-2017 13:08
I concur on the loudness and not being able to adjust. Tried on two different headsets to the same effect.
Best Answer10-11-2017 15:54
10-11-2017 15:54
Ditto. Lowest volume setting is a bit too high on my SENSO bluetooth earbuds.
Best Answer02-16-2018 07:58
02-16-2018 07:58
Same issue, I am using Jaybird Run and lowest setting is still too loud. The earbuds work fine regarding volume using iPhone 6.
