01-17-2018 12:22
01-17-2018 12:22
While in the Run exercise mode with GPS connected Fitbit automatically power off. Had to reset fitbit los
Best Answer01-18-2018 08:42
01-18-2018 08:42
@Adoby64 Thanks for your reply! Have this happened again ever since?
The restart you did is the best thing to do in this kind of cases. This shouldn't happen again.
Also, have you checked this thread already? Can you tell me if the situation you experienced relates to that?
Keep me posted! ![]()
Best Answer01-18-2018 07:21 - edited 01-18-2018 08:49
@Adoby64 Welcome to the Fitbit Community! No, GPS will power off once you have finished the activity on your Ionic. Once you have finished you need to stop the activity and then "finish" it. Then, if you sync, you will see all the data regarding that exercise under your activity history. Check this article for more details.
Are you having any trouble doing this? How are you finishing your exercises on your Ionic?
If your Ionic is turning off while on the exercise, the restart you did should sort it out!
Best Answer01-18-2018 07:34
01-18-2018 07:34
Thanks for your reply... the issue is not GPS powering off... The Fitbit Ionic power off while i was using the exercise Run feature with the GPS. I had to reboot my Fitbit Ionic.
01-18-2018 08:42
